I attached the diagram of the system for you when you are looking for leaks.
Jan 11, 2021 at 8:21 PM
DAVE213
MEMBER
But will the brakes still be firm or not? And how long can someone drive with the spare circuit?
Jan 12, 2021 at 12:07 AM
CERTIFIED EXPERT
No, the pedal will be half at best and the stopping distance will be greatly increased.
I would not drive it that way at all. I would get it fixed ASAP.
Jan 12, 2021 at 3:24 AM
DAVE213
MEMBER
So no floor touching.
I think it gives the same symptoms of failing master cylinder if i am not wrong.
Well, how far can you go if one of the circuit is broken?
Jan 12, 2021 at 3:26 AM
CERTIFIED EXPERT
Again, I would not drive it with the pedal that low. It is an extreme safety hazard and needs to be repaired.
I would not drive more than the distance to a repair shop.
Jan 12, 2021 at 3:38 AM
DAVE213
MEMBER
Yes, i know usually in single circuit system ince the fluid is over the brakes stop working.
Does it take the same time for the dual system to stop working or take longer?
Jan 12, 2021 at 3:42 AM
CERTIFIED EXPERT
When you have only one portion working, the pedal reaction time and distance for stopping are greatly increased as I stated before.
