Juddering and stalling in reverse
2003 ROVER 45
69,987 MILES • 1.8L • AUTOMATIC
BECKY WILLIAMS
  • 4 POSTS
So my vehicle listed above is juddering in reverse and stalling. When it stall it cuts the immobilizer out so I have to wait a bit to start the car again. I don't know what the fault is as I've just bought the car and I've checked the manual to no avail. I thought transmission fluid but there's no dipstick on this model to check it.
Jun 24, 2021 at 3:25 PM
This does sound like a transmission issue. There are two things we need to start with.
First we need to check for codes. Even if the lights are not on, we could have a code that will point us in the right direction. Here is a guide that will help with this:
Next thing is does the vehicle have any issues in drive? What about when you are driving on the highway and then exit and come to a stop? Does the vehicle stall when this happens?
I am thinking we have an issue with the torque converter causing these issues.
Unfortunately we don't have a manual on this vehicle as it is not offered here in the USA but I am sure based on this info we will turn up the issue.
https://www.2carpros.com/articles/automatic-transmission-problems
Let's run through this material and we can go from there. Thanks
Jun 25, 2021 at 6:32 PM
BECKY WILLIAMS
  • 4 POSTS
Hi, no issues in drive and stopping it's just reverse, there no code or lights on. so I'm just really unsure what's going on and it's an automatic.
Jun 26, 2021 at 4:01 AM
Okay. Just to be sure, did you check for codes or are you assuming there are no codes because there are no warning lights on?
There are codes that will set that will be clues with no light set so if you haven't checked then we need to check.
However, if there are no codes then we need to suspect the issue is with the reverse clutch or torque converter.
What I would try before you do anything is adding an additive to the transmission fluid called a friction modifier. Basically this is designed to soften the clutches so they don't vibrate just like conditioner for your hair.
What is causing this shudder is a clutch that is grabbing and not slipping like it should. So if you can add a 4-7 oz bottle to the transmission fluid and then you need to put about 100 miles on it before it works into the clutches.
Take a look at the description to one commonly available. Please let me know if you have questions. Thanks
Jun 27, 2021 at 3:21 PM
