In January I replaced the driver's side wheel bearing. Since then, the ABS light has been on, and I haven't been able to pull a code from the truck. I replaced the ABS Wheel Sensor on the passenger side wheel bearing last weekend to see if it will fix the problem. No dice.
On Tuesday driving to work the truck started to jerk to the right while I was driving under 55-60MPH and when I was decelerating. It's not going to cause me to go off the road, but it is definitely noticeable.
Any ideas about why this is happening? I have not been able to get under the truck and check the front end. I assume that it might be something to do with the passenger side caliper or brake pads?? Would a bad caliper cause the truck to do this at lower speeds?
Any insight would be extremely helpful.
The truck is a 2007.5 Chevy Duramax 2500 HD.
Thank you very much!
May 4, 2022 at 12:41 PM
