1991 Jeep YJ Wont run properly
1991 JEEP WANGLER YJ
65,000 MILES • 4 CYL • AWD • MANUAL
ROSHBURGER
At random times (bust mostly in 2nd gear), when I press and stay on the gas, the Jeep will accelerate, then stop accelerating, accelerate again, then stop again, and start accelerating again, and stop, and keep going like this.
Also, when I try to start the engine it takes a few times (aprrox 4 key turns and holding) for it to start. THe first key turn will turn up nothing. Then before it starts, it sounds as if its struggling to stay alive and then dies. Then I will start it again and it will finally start.
It seems as if the two are related and they are gradually getting worse and worse.
Please any help will be appreciated. Thank you.
Sep 11, 2009 at 2:55 PM
Your clutch could be slipping as far as the key turning problem could be the ignition switch-Bad contact
Sep 11, 2009 at 5:38 PM
