1990 Jeep YJ Smog Check
1990 JEEP WANGLER YJ
128,000 MILES • 6 CYL • 4WD • MANUAL
SMOKIN JEEP
  • 9 POSTS
I have a 1990 Jeep Wrangler 4.2L that I have been trying to pass smog in CA. The Jeep has been running pretty good for an old vehicle and my mechanical experience has been growing vastly since I have had her. She is running 33's w/ stock gears.
Here are the Max and Gross polluter limits
15mph (HC-124(MAX)311(GP),CO-0.75(MAX)2.05(GP),NO-1020(MAX)1807(GP)) for
25mph (HC-104(MAX)261(GP),CO-0.95(MAX)2.25(GP),NO-880(MAX)1607(GP)).
Here are the results of my first test.
15 mph (RPM-1984, %CO2-13.9, %O2-1.0,HC-102, CO-0.53,NO-1965)GP
25mph(RPM-1902,%CO2-14.0, %O2-0.9,HC-105,CO-0.52,NO-1870)GP.
They said the high NO had to do with my EGR system. So I looked at it and the plastic nipple from the EGR temp switch was broken off, so the EGR had no vacuum. I fixed that w/ super glue and EGR gets vacuum and diaphram moves when revved.
Test2
15 MPH(RPM-1952,%CO2-12.3,%O2-0.6,HC-198,CO-3.44,NO-114)Gross P
25mph(RPM-1905,%CO2-11.9,%02-0.6,HC-201,C0-4.02,NO-99).
Now its running super rich. I went through all the vacuum hoses and replaced an re routed them per the vacuum schematic in my chiltons, and now she is idling super high, like 1300 RPM. I'm stuck, does anyone have any idea of what to do?
Apr 22, 2009 at 11:03 AM
RACEFAN966
  • 5,029 POSTS
OK here is a factory vacuum diagram. Check to make sure that everything looks right first ok. Then get back to me after that and let me know how it went.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_76.jpg
Apr 27, 2009 at 8:04 PM
SMOKIN JEEP
  • 9 POSTS
After my second test I started to look at my vacuum hoses. They were not right at all. One line that was supposed to go to the rear of the carb was not there and the nipple on the carb was capped. I have since replaced most of the old vacuum hose and routed it the correct way. I also checked my timing and it was at 9 deg. so that is at factory setting. I still have to take it in for a third smog check.
Apr 28, 2009 at 10:33 AM
RACEFAN966
  • 5,029 POSTS
Did the vacuum diagram I sent help at all as this is a factory diagram. How is the idle did it go back to normal? I would also say run a bottle of seafoam in the gas tank to clean anything out before the test too. Get back to me.
Apr 29, 2009 at 10:27 AM
SMOKIN JEEP
  • 9 POSTS
My idle went close to normal. I adjusted the idle on the carb sol-vac, fast idle and curb idle. It is now idling better than ever. I also ran some seafoam in my tank, down my carb, and some in the oil. I changed my spark plugs, pcv valve, air filter, changed oil 3 weeks ago, and I checked my timing and it is at 9 deg. I took another test yesterday and it did much better, but still not good enough.
Here are the results of my third smog test.
Test RPM CO2 O2 HC CO NO
15 mph 1964 14.0 1.0 124 0.46 219 Pass
25 mph 1929 14.2 1.0 133 0.39 210 Fail
I don't really know what to do now. It is weird that at higher speeds the CO and NO went down, but the HC went up. Now I just need to see what to do to get the HC down. Thank You.
Apr 29, 2009 at 2:45 PM
SMOKIN JEEP
  • 9 POSTS
I also noticed after my 3rd test that my pcv air in tube going to the back of my air cleaner housing had fallen off. I don't know if that would affect the emisions, but I do think it is supposed to have vacuum and that may have been why the motor was running a little rich.
Apr 29, 2009 at 4:02 PM
RACEFAN966
  • 5,029 POSTS
It very well could as if it makes the car run lean then the O2 sensors pic this up and try to correct the issue which in turn would make it run on the rich side.
Apr 30, 2009 at 10:16 AM
SMOKIN JEEP
  • 9 POSTS
I was also using high octane gas. Would that leave more unburned fuel in the exhaust. My jeep is not made for high octane , I don't know it was just a thought. Also I heard some people put on smaller tires and that helps them pass.
Apr 30, 2009 at 4:40 PM
RACEFAN966
  • 5,029 POSTS
Smaller tires does nothing more then change the speedometer rate. As for high octane fuel should not have any affect that way. Most all cars are made to run on 87 octane any higher octane is just really a waste of money. I must ask have you checked the coolant temp sensor? If not then unplug it and check the resistence across the terminal of the sensor (not the wiring harness). Get back to me with the reading in ohms and if you do this cold the air temp at the time of the test.
May 1, 2009 at 10:05 AM
SMOKIN JEEP
  • 9 POSTS
I am at work so I just did a quick test. The motor was warm and I just unplugged the sensor and the idle changed so I think that it is working. I will check it with a meter at lunch.
May 1, 2009 at 10:50 AM
RACEFAN966
  • 5,029 POSTS
Ok good let me know how it goes.
May 2, 2009 at 8:45 AM
SMOKIN JEEP
  • 9 POSTS
Well, here it went
test rpm HC CO NO
15mph 1329 174 0.40 322 Fail
25mph 2136 117 0.42 215Fail
The HC's were too high the max for 15mph were 124 and 104 for 25mph. I failed on the gas cap too, eventhough it was the same one that passed twice. I had changed the oil, put on 31" tires, cap, rotor, and I even put a bottle of guaranteed to pass. And no dice. The tires helped a little on the 25 mph test, but he did the 15mph test on a higher gear so the rpm's were a lot lower. I think the only other option i have is to get a new cat. I guess i could advance the timing or put rubbing alcohol in the tank. This sucks.
May 8, 2009 at 12:19 PM
RACEFAN966
  • 5,029 POSTS
Refresh my memory have you checked or replaced the O2 sensor?
May 9, 2009 at 8:14 AM
SMOKIN JEEP
  • 9 POSTS
Yes I replaced my O2 sensor about 1 month ago. I also checked the voltage on the stepper motor and it fluctuates like it is supposed to.
May 11, 2009 at 10:59 AM
RACEFAN966
  • 5,029 POSTS
Ok have you checked the map sensor at this point? How is the PCV system is the valve working? DId you check the vacuum diagram that I included to make sure everything was correct? Get back to me thanks.
May 11, 2009 at 7:10 PM
SMOKIN JEEP
  • 9 POSTS
I don't think I have a map sensor. The PCV valve is new and I used the same vacuum diagram. I hope its not the cat.
May 14, 2009 at 11:37 AM
