My jeep has been stalling when coming to a stop both in gear and out of gear. It does it every once in a while. What could be the problem??
Jan 28, 2009 at 3:37 PM
CERTIFIED EXPERT
Check the idle air control valve/motor/ISC, throttle position sensor, PCV and EGR valves
Jan 28, 2009 at 4:46 PM
HUNGRYEDDY
MEMBER
you jeep is an 88, carburated. you probably need to replace your carb, look into doing an mc2100 swap and nutter bypass, that fixed mine instantly and made it better
