'97 Wrangler Defroster
1997 JEEP WRANGLER
FXDL2003
We have a '97 Wrangler and the defroster does not work. The heater kicks @#$ on the floor and dash. But when we switch it to defroster it does not switch to the windshield vent. The defroster vents for the passenger/diver windows work. Is there a way to check this and repair it?
Thanks,
Andy
Dec 10, 2006 at 9:21 AM
CARUNDELL
  • 602 POSTS
[quote:dd5eda7f8c="FXDL2003"]We have a '97 Wrangler and the defroster does not work. The heater kicks @#$ on the floor and dash. But when we switch it to defroster it does not switch to the windshield vent. The defroster vents for the passenger/diver windows work. Is there a way to check this and repair it?
Thanks,
Andy[/quote:dd5eda7f8c]
Hey andy,
The heater/defrost control "doors" are controlled by vacuum, check under the hood and find the small vacuum line that goes thru the firewall and make sure its attached to a vacuum riser on the motor. Check under dash at or around the heater box for broken or disconnected vacuum lines. Hope this helps!
Regards,
Chris
Dec 11, 2006 at 11:01 AM
FXDL2003
Thanks, I had the control unit out and noticed all the vacum lines were attached, I did not check at the engine and firewall. Thanks for the tip. I'll check this out soon.
Andy
Dec 11, 2006 at 6:31 PM
