i have a '93 jeep wrangler 4.0L 5spd. i have performed a very novice frame-off restoration over the last couple years. i put a 3.5" suspension lift and a 2" body lift on it. the suspension lift actually required the transmission be lowered about two inches, as well. my master clutch cylinder hose is broken and i need to replace it. an OEM replacement is about $90, and seems rather rediculous, especially since i don't know if it is even long enough due to my modifications. my question is...is there any kind of hose that i can use that would replace it safely and cheaply? or, if i do get the oem replacement, will it be long enough?
Dec 19, 2006 at 8:44 PM
