hello, i have a 91 wrangler,6cyl. with about 150,000 mi. on it, the gauge cluster quit working all of a sudden, the rpm,temp,oil press,fuel,battery, none of those are working now, the speedo and clock still work, i have pulled and visually checked every fuse on the vehicle they all appear to be good. i dont know what else to check. it was working fine and then on a kind of rainy day i cranked it up and the gauges quit working. i just put a new ignition and key assembly in right before this happened but it was working fine after i got done. got any ideas what it may be ? i also have one more question, i am haveing trouble putting gas in the vehicle,it seems every time i go to fill up i have to run the pump at a very low volume to keep it from backflowing and shutting the pump off, i checked the filler neck and vent hose for kinks but they are fine. ????????
May 31, 2007 at 1:24 PM
