2006 Jeep Wrangler Starter ?
2006 JEEP WRANGLER
19,500 MILES • 6 CYL • 4WD • MANUAL
RONNDANNY
My Jeep will not start. When I turn the key I get a click, click. When I hook up jumper cables it doesn't help. could this be my starter ? Is there anything else I should be looking into ?
Aug 18, 2009 at 8:12 AM
WINEBURGER
  • 82 POSTS
if you tap on starter with hammer and it cranks. replace starter. do this while somebody is turning key . if not it could be your connections main starter wire or grounds . or it could still be a faulty starter . if if you try turning your key for run to start and one of those times it cranks you have a faulty solinoid. its on top of the starter
Aug 18, 2009 at 8:34 AM
