2005 Jeep Wrangler instrument cluster
2005 JEEP WRANGLER
58,000 MILES • 6 CYL • 4WD • AUTOMATIC
WNEGROTTO
my instrument cluster stopped working as well as my
interior light yesterday. What could be my problem
Jan 27, 2009 at 9:25 AM
KEVIN20464
I just had the same problem,the instrument cluster powers the dome light and the door ajar lights.You have to got to the 100 wire connecter under left side, drivers side and find if you have power to the blue/green wire which goes to the C1 connecter behind the instrument cluster. If you have power there chances are the circuit board is bad, go to a wreckers as they are quite expensive. Additionally if no power at the 100 wire connecter the instrument cluster is fed through the rear window defogger relay which is located in the fuse box on the right side of the engine compartment.
good luck
Jan 16, 2011 at 1:03 AM
