I recently got the following engine codes: (i use a product called the ScanGuage II for reading the codes)
p0016 ( Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A)
p2302 (Ignition Coil Secondary #1 Circuit )
I looked up the codes and got the above the information, but i have no idea what this actually means.
At the moment, the dealership replaced the coil and plugs (they claimed the plugs were fouled) and they still had an issue of it only running on three cylinders they said, so next up is the PCM.
They also claim to not know about the P0016 code at the moment.
I need some help here. I have an extended warranty and the PCM wont be in for another week, but i dont think the PCM is the problem, or at least the only problem left.
Also, the extended warranty company doesnt want to cover the spark plugs as they are not warrantied, but my argument is that if a warrantied part falied and caused the plugs to foul, then they should be coevered.
Any help would be appriciated.....
May 16, 2008 at 1:07 PM
