I have a 2004 Jeep Wrangler that has a noticable shake that begins around 40 MPH and progressively worsening at higher speeds. I have new brakes/pads/rotors/drums all away around. New tires that are balanced and no bent rims. I've inspected the front end and have no visible defects or abnormal tire wear. Can you help advise which component/s may be the most likely problem? Also, I don't have any aftermarket lift kit and am running slightly larger than factory spec BF Goodrich all terrain TA tires.
Nov 28, 2008 at 12:01 PM
