Transmission problem
2002 Jeep Wrangler 4 cyl Four Wheel Drive Manual
i have replaced the clutch, pressure plate, bearing, and slave cylinder inside the trans. i have repeatedly bled the line coming from the resevior and can not get the clutch pedal to stay firm. i end up pumping the pedal to get the clutch to work but as soon as i get down the road and need to shift again i have to start the process over again. the only time it works good is rite after its been bled. when i put the new slave in i made sure to read the directions and installed it properly, not removing the keepers that came on it from the manufacturer. please help, shiftless
Feb 9, 2010 at 6:04 PM
