code P0503?
2002 JEEP WRANGLER
90,000 MILES • 4 CYL • 4WD • MANUAL
JAGRAVES2
bumping and hesitating has lessened, but when idling the Jeep runs at about 2300 to 2800 RPM. Way up from the usual 500-700. I now get an error code P0503 for the Speed Sensor being erratic. I have looked through my Repair Manual and cannot find reference to a speed sensor. Is this the same as the throttle sensor? Can someone please help me identify what the new problem might be?
Oct 19, 2009 at 9:41 PM
It is unlikely that this code is related to the erratic idle. If you have a high idle then that is most likely due to an air intake sensor or even a vacuum leak.
Here are a couple guides that we need to run through in order to figure this out:
https://www.2carpros.com/articles/engine-idles-too-high
Please let us know what you find with this info. Also, I attached the info below on the speed sensor. Please run through this info and let us know if you have questions. Thanks
Jul 13, 2021 at 7:04 PM
