2001 rear brake noise
2001 JEEP WRANGLER
POTATE311
I recently bought my 2001 wrangler with 64,000 miles. It has been lifted and larger tires and wheels are on it. I just did some routine maintenance that included rotating the tires. When I was finished and had all 4 wheels back on the ground, I drove a short distance and noticed a grinding brake noise coming from the passenger rear wheel. Thinking something could have gotten dislodged inside the drum while rotating the tires, I came home and took that wheel and drum off. I could not see anything out of place, so I cleaned it up really well and put it all back together. It still makes the noise. The strange thing is that it only makes the noise at speeds between 10-15 mph and while slowing down, not while speeding up. The brake does not have to be applied to make the noise, but it is definitely a brake type grinding noise. The shoes and drum are in good shape, and everything else seems fine. I am stumped.
Oct 24, 2007 at 1:46 PM
MERLIN2021
  • 17,250 POSTS
It sounds like you need to remove the drum, scrape out the groove that the backing plate rides in, rust will do this to you!
Oct 24, 2007 at 2:23 PM
POTATE311
[quote:a1cbb66cc9="merlin2021"]It sounds like you need to remove the drum, scrape out the groove that the backing plate rides in, rust will do this to you![/quote:a1cbb66cc9]
There were quite a few rust chips in there when I took it off. I'll try it. Thanks!
Oct 24, 2007 at 7:57 PM
