I have a jeep that ran ok, then I shut it off and the nest day the battery would run down. I checked that everything was off and attached a battery charger, it started 45 min later and would run fine. I thought it might be the battery so I put in a new one,it did the same thing.We put a volt meter on the negetive post that was unhooked and the negetive cable and it was pulling 12.8 volts with everything shut off. I was told it could be the alternator, but it took off the wire that runs to the battery and it still pulled the same volts. I did not unplug the other wire going to the alternator.Does that wire run the internal voltage regulator, and if so would thar run down the battery?
Oct 19, 2010 at 9:15 PM
