I recently replaced the clutch (entire set), and slave cylinder. The system was bled but the vehicle still wont go into gear when running. With the engine off, I can run it through all gears. Could the master cylinder be the problem? I do hear a very faint chattering with the engine running and clutch pedal depressed to the floor. The noise goes away when I relase the pedal. All fluids are of the right type and full in the tranny. And the tranny was fully supported as it was installed.
Apr 5, 2008 at 9:57 AM
