2000 Jeep Wrangler Lifter Knocking
2000 JEEP WRANGLER
113,000 MILES • 4 CYL • 4WD • MANUAL
DERDA
  • 15 POSTS
I was recently flooded my jeep when I fell into a sink hole and the tide came in. Notice you can see the guys flip flops in the water and this was what the hole looked like when I went to cross it.
I was told I was lucky because I got everything working again and it is running well. However I have a knocking when I start my jeep and it goes away after it warms up. I was told to change the oil to 10W40 to help out and I did this.
1st Knocking is still there how long do I have before I have no choice to replace this?
2nd Second what all is involved to do this and what do I need?
3rd Since I will have to do it are their any performance upgrades I can do that since I'm in this neck of the woods?
4th Fourth how do I do this?
5th The last is if I asked a good mechanic to do this [img:b6a27ed25a]http://www.2carpros.com/forum/automotive_pictures/205139_here_it_comes_1.jpg[/img:b6a27ed25a]
[img:b6a27ed25a]http://www.2carpros.com/forum/automotive_pictures/205139_its_not_that_wide_its_ok_seriously_its_ok_1.jpg[/img:b6a27ed25a]
[img:b6a27ed25a]http://www.2carpros.com/forum/automotive_pictures/205139_Know_the_area_you_jeep_in_1.jpg[/img:b6a27ed25a]how long should it take.
Jul 25, 2008 at 2:20 AM
MASTERTECHTIM
  • 4,750 POSTS
i cant really give a accurate answer without hearing the noise. first you have to make sure its a engine knock and not a exhaust manifold leak (they will sound the same) a exhaust leak will go away after the manifold heats up.
Jul 25, 2008 at 3:50 PM
DERDA
  • 15 POSTS
I don't hear it after driving for a couple of minuets. I just was going by what a mechanic friend said he beleives it is a lifter.
Jul 25, 2008 at 9:31 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
A sticky lifter might be the culprit. I am not sure if the engine was running when you went into the water there (looks like you have a snorkle but I cant tell) but if the engine ingested any of it then it might be a cause for concern. You can try heavier weight oil (unigrade), lucas motor oil additive, or seafoam; however, removing the head and having it cleaned as well as the lifters would be the most effective choice.
Aug 7, 2008 at 3:24 AM
DERDA
  • 15 POSTS
No snorkel, when it happened we tried to start it after we pulled it out. I did use a bottle of lucas oil with 3 quarts of 10w30, as if now I have prestone high milage 10w40 in it now. I'm in an area of unknown but need the help that I can or ideas.
Aug 7, 2008 at 1:10 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
It would be best if you removed the cylinder head and had a good look at everything. I doubt you have a bent valve, but a spring leakdown test would be beneficial. The lifters will need to be inspected and cleaned too.
Aug 7, 2008 at 6:42 PM
