1999 Jeep Wrangler My jeep will not produce heat through th
1999 JEEP WRANGLER
100,000 MILES • 4 CYL • 4WD • MANUAL
MRAYCOCK
The fan works, but has no hot air coming from the vents. I have replaced the thermostat and still no heat. The upper radiator hose gets hot, however the heater hoses do not. Also the lower radiator hose isn't hot or warm either. I have no leaks, and the temp gauge doesn't go much farther than 210, of course i haven't driven very far because it has no heat. Please let me know what you think or if there is any thing else i should check.. Thank you...
Nov 23, 2008 at 3:35 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Blocked heater core probably caused by sediment and mineral deposits. You can verify this by removing the heater core and inspecting the system for blockage.
Nov 27, 2008 at 12:12 AM
