1999 Jeep Wrangler Erratic Turn Signals
1999 JEEP WRANGLER
135,000 MILES • 6 CYL • 4WD • MANUAL
BABYBUF
Ok Gentlemen, '99 Jeep wrangler. When I apply the left turn signal it blinks both rear lights. When the brake is applied both tail lights light, but no blinking. When I try the right turn signal it works perfectly with or without the brake applied. I have changed out all the bulbs and checked the wiring(as best I can) and it seems to be intact. Any ideas?
Aug 12, 2009 at 4:06 PM
BULLETHEAD
Hey, Babybuf did you get an answer to your question? I have the same problem with my 2000 Jeep Wrangler. I have been trying to fix it for some time now. I have changed out the bulbs, I even disconnected the third brake light on the tire carrier. I hope you get an answer because I need to fix it, it is driving me crazy. Oh if you can please answer me at [email protected]
thanks
Bill
Sep 3, 2009 at 3:39 PM
DOCFIXIT
  • 18,828 POSTS
Faulty turn signal switch
Sep 3, 2009 at 3:49 PM
BABYBUF
After a ton of investigation I discovered the previous owner did a hatchet job on the wiring when he tried to splice in the towing connection.
Bottom line I had to replace the wiring to all the lights in the rear. Now I have no problems.
Sep 3, 2009 at 6:08 PM
