Hi guys...trying to determine what is causing a chirping noise from front of my 4.0 engine...serpentine belt is tight, no obvious drips, no change in engine temperature on gauge, no change in voltage, occurs at all speeds, is not dependent on a/c operation. I'm wondering if maybe my water pump is going out, but doesn't that usually show itself in the form of antifreeze weeping from the pump? Tough to tell with a basic shake on the fan shaft, because I have a clutch fan, and it moves freely enough to not be that. What do you think? Please let me know
Feb 23, 2008 at 9:38 AM
