1999 Jeep Wrangler blower motor resistor
1999 JEEP WRANGLER
140,000 MILES • 6 CYL • 4WD • MANUAL
DANINMI
I have done some research on this problem and I question if this will fix all of my problems. I have been told that the Juice goes threw the blower motor resister for "Low", "Medium-Low" and "Medium-High" and the setting "High" the juice comes straight from the battery. My original problem was that "High" didn't work at all and "Medium-High" had to be encouraged to work. Recently, since the cold started this winter, I have lost "Medium-High" completely. It makes sense that replacing the blower motor resistor will fix "Medium-High", but will it also fix "High"?
Jan 4, 2010 at 6:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
May want to check the blower motor relay. If HIGH setting is not working then the resistor is not at fault. It may be melted wiring at the resistor, but resistor itself can not stop HIGH from working as it is direct power. Blower motor itself or heater / a/c control switch is most likely at fault if the relay(s) is good.
Jan 22, 2010 at 3:22 PM
