1998 wrangler cruise control problem
1998 JEEP WRANGLER
ROCKETGUY
  • 5 POSTS
I am installing a factory MOPAR cruise control kit into my 1998 jeep wrangler 67,000,6cyl,auto,4WD, only new tires and brakes as repairs. It runs great. I am having problems getting it to work. The service manual indicates that the steering wheel mounted speed control switches (left and right)must have continuity and specific resistance readings on verious settings. My original switches (new)gave no continuity, and no resistance readings...ZERO. Then I decided to order a new set of switches to solve this problem. They turned out to be the same as before. No continuity and no resistance readings whatsoever. Do I have four bad switches? and what do you recommend that I do next?
Jul 17, 2007 at 7:36 PM
2CARPRO JACK
  • 11,533 POSTS
Are you testing them through the wiring in the column or removed from the wheel? There is a "clockspring" contact plate under the steering wheel for the switches
Jul 18, 2007 at 8:15 AM
ROCKETGUY
  • 5 POSTS
Jack: I have the switches removed and am checking for continuity across the wiring connection leads on the switches as specified in the 1998 wrangler shop manual. I get no continuity when I do this. The manual says that I should get continuity and various resistances as the various switches are engaged. I have the manuals sections (you need speed control and brakes)and can email to you If i knew how with this setup here. Carl
Jul 18, 2007 at 9:11 AM
2CARPRO JACK
  • 11,533 POSTS
Are you doing this with them plugged in?
Jul 18, 2007 at 12:14 PM
ROCKETGUY
  • 5 POSTS
no just like the manual says free standing on the bench. I also sent you 3 manuals to help with this problem to the webmasters email address. You should read these for more info.
Jul 18, 2007 at 4:21 PM
2CARPRO JACK
  • 11,533 POSTS
If you have 4 switches that you cant get a continuity reading through, I would check the meter you are using, battery may be low.
Jul 19, 2007 at 7:36 AM
ROCKETGUY
  • 5 POSTS
Jack The volt meter is not the problem already put in a new battaer an had my neighbor (electrical engineer) theck the swithcheswith his meter. same result they are dead dead dead.
Have you received the 3 manuals that I sent to you via youe web master . you need to read these if you are going to help me.
carl
Jul 19, 2007 at 8:01 AM
