I just bought this Jeep with current issues. The Jeep will spin over fine, will display odometer reading in dash and show brake light and abs will go through normal cycle, but check engine light is not coming on and fuel pump is not working either. Also dont have any power to ingition coil when key switch is cycled on. I can't get the ASD relay to click when ignition switch is turned on and have swapped with other relays in hopes that was the case. I have checked for power at PCM connections with a test light and found that connector closest to engine has 12v on #1 terminal. connector closest to fender has voltage at #3 terminal and when touched with test light and key switch on, ASD relay clicks on. But Jeep still won't start, and there is no spark at plug wires. Just so where all on the same page, I bought this Jeep with a locked up motor and the "lady" i bought it from replaced the water pump I'm assuming after she ran it hot. Then the motor seized up and she thought the battery was dead due to clicking sound, so she installed a new battery and still just clicked. So next she installed a new starter. Same problem. So, after i got it home, I pushed the Jeep down a hill and popped the clutch and got the motor unstuck, figured I could crank the bucket and hear it knock before i put a new motor in it, but I have to get this issue addressed before I start trying to install a new motor that still wont crank. I have checked all fuses and everything I know of has power in the dash and in the PDC.
Aug 13, 2010 at 9:17 PM
