1998 Jeep Wrangler knocking
1998 JEEP WRANGLER
175,000 MILES • 4 CYL • 4WD • MANUAL
SHILLITOCHRIS
I blew a push-rod in my jeep...fixed it, and i'm still getting alot of knocking from the lower end of the motor.
Feb 3, 2009 at 1:26 AM
MECHCURT
  • 184 POSTS
Check the oil pressure before you drive it to much. Something made the push rod fail for you. If its low than it is possible that yoiu have worn rod bearings and main bearings. If they have not scarred the crank I have gotten away with installing new ones and getting alot of miles out of the engine. You will need to plasti gauge all the bearings to know where your at. Just make sure the crank has no damage. Let us know Curt
Feb 8, 2009 at 11:05 AM
