jeep starts fine, after 1 1/2--2 minutes, idle will drop to just about stall, and then snaps back to proper idle. this happens all kinds of weather. if i drive before it has this tantrum, it will drop r's, and backfire, i can drop clutch and rev with no propblem, but if i try to accelerate to get it going, it backfires, it wants to go through this low idle phase again. ive replaced plugs and wires, and cleaned the idle air control, (as to your advice) along with spraying carb cleaner into tbi. once it goes through its tantrum, it runs fine, but all it takes is to shut down for a matter of minutes and it wants to repeat this problem. i should also mention that this vehicle sits for a week at a time, im an otr driver, so i only get to play in it on weekends
Apr 2, 2010 at 7:57 PM
