1998 Jeep Wrangler Instrument panel Goes Dead
1998 JEEP WRANGLER
90,000 MILES • 4 CYL • 4WD • MANUAL
XREY
Everytime I hit a bump, or just driving along, the instrument panel just goes dead. Still lit, the airbag indicator comes on, no speedometer/tach/oil/battery/temp indicators. I hit the top or bottom of dash and it comes back on. No wires or fuses are loose, as I have had it checked several times. Do I need a new wiring system?
Sep 30, 2010 at 6:26 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile I do not know much about your rig. I recently bought a Dodge shadow---to flip, so I could buy a set of tires for my Jeep CJ 5 and some other necessary stuff too. The Dash stuff did not work on it either, unless you Smacked the Dash I can tear into things pretty EZ, I have a Large set of Every kind of bit imaginable----Christmas present from somebodyIt came from Walmart. I already do have most of whats included, But this is cool, in the fact that it is ALL TOGETHER in this kit! There were several types of fasteners holding the Instrument Cluster in the dash. It was not hard to remove the clusterI let it stay connected to the 2 sets of wires. While it was attached, with the key on, I wiggled the wires to verify this was where the problem was. One at a Time, I depessed the latch of the RECTANGULAR CONNECTORI removed and replaced the connector 4-5 times then snapped it back in----I did this to BOTH CONNECTORS. This sorta scraped and cleaned the connections. It fixed my problem! The connection on the cluster was MERELY a printed circuit on a FLOPPY plastic type mat. If this is not your source, wiggle the stuff around that you can reach.........maybe this will help you! Your Turn The Medic
https://www.2carpros.com/forum/automotive_pictures/411289_WILLY_ALWAYS_KEEPS__A_STRAIGHT_FACE_1.jpg
Sep 30, 2010 at 11:52 PM
