I have a 1998 wrangler that was hit in the front then repaired (if that matters) The check engine light is on all the time it runs good at times then will
have no power with backfire at cruising speed
almost like it is running out of gas. At times the gauge panel goes dead, no speedo,tach, temp,
oil press, ect the truck still will run though.
when idling the truck seems to be choking itself out
running way rich. does anyone have a clue where to start?
Thanks
adh
Thanks
adh
Apr 17, 2008 at 2:23 PM
