Engine Performance problem
1997 Jeep Wrangler 6 cyl Four Wheel Drive Manual
i have a 1997 jeep wrangler with 4.0l i-6 iam getting a p0300 dtc i have replaced all ignition componets including the camshaft position sensor i ran compression check on all cylinders and they all were above 158 psi also checked fuel pressure which was in spec the problem is the engine runs fine till about 3000 rpm the i get the p0300 code?
Sep 28, 2008 at 2:44 PM
