1996 Jeep Wrangler Fuel in oil
1996 JEEP WRANGLER
ARTE
Engine Mechanical problem
1996 Jeep Wrangler 6 cyl Four Wheel Drive Manual
What symptoms can be expected from fuel getting into the crankcase?
Besides Piston wash and bearing damage, I would like to know what to look for as far as power,Exhaust ect.
Thanks.
Nov 12, 2008 at 5:32 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Extremely rich. Besides what you mentioned about pison wash you can change the critical chamfer gap on the valves. Heavy carbon buildup on the spark plugs. Detonation might occur in the cylinders due to increased compression/smaller area because of carbon buildup. Catalytic converter(and maybe even the muffler) can become completely clogged, EGR valve can become inoperable. CCV system will actually draw a significant amount of hydrocarbon vapors into the intake that could cause gum and varnish buildup and throw off the MAP sensor.
Nov 27, 2008 at 12:53 AM
