How to remove wiper motor?
1995 JEEP WRANGLER
ANNIEKATZ
Other Category problem
1995 Jeep Wrangler 6 cyl Four Wheel Drive 85000 miles
How do I remove the wiper motor. Does anyone have a diagram?
Thanks
Dec 15, 2007 at 12:22 PM
MERLIN2021
  • 17,250 POSTS
This is what I came up with...
https://www.2carpros.com/forum/automotive_pictures/62217_Wiper_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Wiper2_1.jpg
Dec 15, 2007 at 1:06 PM
This is all they give for alldata
1. Disconnect negative battery cable.
2. Lift wiper arm until holes in arm and arm base align, insert a pointed tool through holes to lock arm, then grasp arm near base and rock arm while pulling up to remove.
3. Remove top and top components sufficiently to allow windshield to fold forward.
4. Remove windshield retaining bolts at lower corners of instrument panel and fold windshield forward.
5. Remove three torx head wiper motor mounting screws, then disconnect wiring harness clip from base of windshield.
6. On models with intermittent wipers, remove mounting screws from intermittent module bracket at base of instrument panel.
7. Disconnect wiring harness clip from base of windshield.
8. Remove plastic cover over access hole in windshield frame, if equipped, then pry drive arm off wiper linkage.
9. Remove seal to windshield frame screws, that may interfere with drive arm and motor removal.
10. Pull drive arm and motor from windshield frame.
11. Pry drive arm from motor pivot.
CAUTION:
Do not remove nut holding pivot to motor shaft.
12. Reverse procedure to install. Torque motor mounting screws to 96 inch lbs.
Oct 23, 2024 at 5:43 PM
