1995 Jeep Wrangler help
1995 JEEP WRANGLER
8,500 MILES • 4 CYL • 4WD • AUTOMATIC
DESERT_ANGEL
  • 8 POSTS
i,am not getting any power to the computer,and can not locate the power wire for it.the book says that the power wire is yellow, but there is not a solid yellow wire going to the computer.[img:cefeef9574]http://www.2carpros.com/forum/automotive_pictures/307869_my_jeep_007_1.jpg[/img:cefeef9574]
[img:cefeef9574]http://www.2carpros.com/forum/automotive_pictures/307869_my_jeep_005_1.jpg[/img:cefeef9574]
Jan 25, 2009 at 9:09 PM
DOCFIXIT
  • 18,828 POSTS
At PCM term. #3 Red/White wire 12v key on
trem #6 Violet?White 5v
term #8 Orange 8v
Check ASD auto shutdown relay in power distribution center under hood.
Jan 26, 2009 at 2:43 PM
DESERT_ANGEL
  • 8 POSTS
i,am more than willing to make a donation, but i only get paid on the 3rd of every month please send me a reminder notice so i can send a donation to get this jeep running is important to me.i,m sure i,ll have more ? to come.i do my own work but as a female i,m still learning.i cant thank you enough.
https://www.2carpros.com/forum/automotive_pictures/307869_my_jeep_005_2.jpg
Jan 26, 2009 at 3:05 PM
DOCFIXIT
  • 18,828 POSTS
Don't worry about donate lets just get you back on the road. ASD is a common problem and if it does not click next to it is a relay just like it swap see if it starts. Also check voltage to coil and do you have fuel pressure?
Jan 26, 2009 at 3:12 PM
DESERT_ANGEL
  • 8 POSTS
yes we have power to the coil, and no we have no fuel pressure
Jan 26, 2009 at 3:38 PM
DOCFIXIT
  • 18,828 POSTS
Then ASD relay is most likely fault
Jan 26, 2009 at 3:45 PM
DESERT_ANGEL
  • 8 POSTS
[quote:f98da76164="Docfixit"]Then ASD relay is most likely fault[/quote:f98da76164]
he swaped the relay out but still no check engine light.
Jan 26, 2009 at 3:53 PM
DESERT_ANGEL
  • 8 POSTS
he swapped out the relay but still no check engine light.
Jan 26, 2009 at 3:56 PM
DOCFIXIT
  • 18,828 POSTS
What did you get on term3,6,8?
Jan 26, 2009 at 4:09 PM
DESERT_ANGEL
  • 8 POSTS
no power to 3,6,or8
Jan 26, 2009 at 4:10 PM
DOCFIXIT
  • 18,828 POSTS
O.K.
Going to ask around to other 2car techs and see if I can get an answer.I'll get back on line tomorrow at 8EST I know that's a little early for you but check when your up and hope i can give you the solution
Jan 26, 2009 at 4:20 PM
DESERT_ANGEL
  • 8 POSTS
thank you so much for the help you are offering. i,m so gratefull.
Jan 26, 2009 at 4:24 PM
DOCFIXIT
  • 18,828 POSTS
Don't sell the farm check fuse #3 in power dist. center 30amp
Jan 26, 2009 at 4:29 PM
DESERT_ANGEL
  • 8 POSTS
all the fuses are good, we checked them all.
Jan 26, 2009 at 7:45 PM
