Hello – Not knowing your friend makes that a hard question for me. On your vehicle you have to remove the intake manifold also. There are numerous components attached and in the way of removing the manifolds. Understanding that there is bolt tightening sequence that must be followed: Knowing that especially on the exhaust manifold the nuts/bolts may need to be soaked in a penetrating oil sometimes since they are almost welded on at times to include the exhaust attached to them is a biggie.
Some things to know is has he done this before? Has he ever removed heads, or pulled engines before. Then yes, he could surely do it. Most of it is a step by step sequence that a general mechanic can follow to include the correct bolt tightening sequence and the use of a torque wrench.
For you….the customer in this part, please make sure you understand this isn’t always easy. A rough labor rate that he is saving you is about $700.00. Things happen though. He may have to end up cutting the exhaust flange bolts off. That’s additional cost, low but still cost. Worse case, there is a technical service bulletin out on some of your manifold bolts/studs breaking. That means your heads may have to be pulled to get them out. So these things are not his fault that you would need to understand and realize that if you were at a shop things would happen there too. He is very kind to offer. Believe me. Not an easy task and if you were to help then it would give you a better understanding of the problems encountered and give you a sense of security that he does a good job. As I said, I feel a general mechanic can do it, just be understanding if thing break.
Nov 1, 2008 at 1:58 AM
