1995 Jeep Wrangler Engine drop off
1995 JEEP WRANGLER
110,000 MILES • 4 CYL • 4WD • MANUAL
HORSTMT
Hi, I have a 1995 Jeep Wrangler that is 10000 miles away from a complete engine rebuild (new engine, exhaust from manifold to muffler, alternator, radiator, transmission, etc...) It was running fine but has developed a jerk at lower speeds and when accelerating in any gear. I have replaced the throttle body, plugs and wires with no change. Any suggestions would be greatly appreciated.
Sep 18, 2009 at 4:47 PM
MATHIASO
  • 1,209 POSTS
if you have engine light, or engine code(s) will help to narrow the problem(s) down.
Sep 18, 2009 at 11:21 PM
HORSTMT
the engine light is not on and I'm still trying to find someone that has the correct adapter to read the ECM for codes.
Sep 19, 2009 at 10:31 AM
MATHIASO
  • 1,209 POSTS
how is the transmission fluid level?
Is the RPM higher than normal when accelerating or it just normal?
how is the fuel filter?
check also if the timing is wrong.
let me know
Sep 24, 2009 at 12:53 AM
