1995 Jeep Wrangler engine cuts off
1995 JEEP WRANGLER
132,000 MILES • 4 CYL • 4WD • MANUAL
My engine cuts off after driving for a while randomly, and if I wait a few minutes I can start it again and drive-on?
Sep 16, 2010 at 7:13 AM
WRENCHTECH
  • 20,761 POSTS
I can tell you that a common failure that will act that way on those is the Crankshaft Position Sensor but we never change parts simply on a guess. We verify things through a systematic set of tests but a realize that can be difficult on an intermittent problem.
Here are the tests.
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
4) If all of these things check good, then you would need to do a complete compression test.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Sep 16, 2010 at 7:33 AM
