1988 Jeep Wrangler ENGINE STARTING
1988 JEEP WRANGLER
132,000 MILES • 4 CYL • 4WD • MANUAL
LEESTL
  • 4 POSTS
ENGINE STARTS,BUT SHUTS WHEN I RELEASE IGNITION SWITCH. WILL RUN WITH STARTER FLUID OR GAS PUT INTO THROTTLE BODY MOUTH. I REPLACED FUEL RELAY,PUMP,AND FILTER. IDONT HAVE FUEL PRESSURE GAUGE, BUT SEEM TO HAVE GOOD PRESSURE AT LINE GOING INTO THROTTLE BODY. LOOKED FOR VACUUM LEAKS AND TIGHTENED BOLTS ON INTAKE MANIFOLD.IS THERE A WAY TO VERIFY FOR CERTAIN THAT THERE ARE NO VACUUM LEAKS OR SUCKING AIR AT INTAKE? I ALSO REPLACED THE EGR VALVE. THANKS
Aug 19, 2010 at 2:50 PM
What you need to do here is check and test the ignition switch. The ignition circuit could be open-Do this fire it up -when it dies leave key in the ignition and check for power at the coil positive terminal, do you have it?
Aug 19, 2010 at 5:14 PM
LEESTL
  • 4 POSTS
I DO HAVE POWER TO COIL
Aug 20, 2010 at 2:13 PM
Verify the fuel pressure if its within specs
Aug 20, 2010 at 3:20 PM
LEESTL
  • 4 POSTS
fuel pressure is good
Aug 27, 2010 at 9:13 PM
Okay -this time when it dies out leave the key at On position and check for power at the coil positive-if nothing there -the coil primary circuit to the key is open or the ignition switch is defective
Aug 28, 2010 at 2:02 AM
LEESTL
  • 4 POSTS
There is power to coil
Aug 28, 2010 at 6:58 AM
Are the fuel injectors pulsing?
Aug 28, 2010 at 7:07 AM
