1984 Jeep Wrangler stoling when foot off gas
1984 JEEP WRANGLER
164,000 MILES • 6 CYL • 4WD • MANUAL
CIAFARDINI
The Jeep starts but every time i take my off of the gas it stoles. I checked and i have gas in the car.
Thanks
Jun 20, 2009 at 2:35 PM
First, your jeep has a carb on it and not fuel injection. Make sure there are no vacuum leaks around the carb and the engine area. Many times the vacuum lines get hard and dry rot causing a leak. If there are no leaks, there is an adjustment on the carb that wil adjust the idle speed. You may need to adjust it.
Let me know what you find. Also, sometimes you can hear a hissing sound from a vacuum leak when the engine is running. Make sure you are careful around the fan and other moving parts.
Jun 29, 2009 at 10:10 PM
