1993 Jeep Wagoneer Jerking into first gear
1993 JEEP WAGONEER
153,000 MILES • V8 • 4WD • AUTOMATIC
ENAKAGUMA
When my engine is hot and I come to a complete stop, wehn i accelorate, it won't shift into gear, then suddenly jerk into first. Once in first its okay until I stop again. Also, at about 55 mph, the tach suddenly drops up and down rapidly then stabilzes. I just change the trans flluid and filter but its still doing the same thing. It also feels like its being held back when accelorating. Could low diff fluid be the cause?
Aug 7, 2009 at 3:01 PM
I doubt the differential fluid would cause this. The differential wound make a noise. If you feel a jerking, have you checked to make sure the motor mounts and trans mounts are good?
Aug 28, 2009 at 5:16 PM
