Electrical problem
1978 Jeep Wagoneer V8 Four Wheel Drive Automatic ALOT miles
When my Dad had the Jeep the window was working fine. Now I cannot get it to do anything. The ONLY power I can find that is hot inside the tailgate is the Red wire with the white stripe.
Frankly I do not care about the rear window defogger or if it ever works again. How can I figure out if one if the solenoid switches went bad, (There appears to be 2). If the motor is bad or if I can bypass the wiring and hook it up so that I can use a new switch up front. The key switch does not operate the window either.
Is there a kit to convert it from Power to Manual? I would prefer that anyway. My cousins who bought the Jeep when it new said that there always seemed to be a short that nobody could find and abandoning it seems o be a good fix for an old vehicle like this one.
Any help would be greatly appreciated.
Thanks.........
Thanks.........
Apr 5, 2009 at 4:14 PM
