2004 Jeep TJ Changing Differential oil
2004 JEEP WRANGLER TJ
44,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICTRIK
I notce than many shops (including dealerships) do not remove the differential covers when changing the differential fluid. I believe they pump out the old oil. would this be considered a shortcut and would it be likely to cause problems "down the road"? Please forgive the pun...
Feb 26, 2009 at 3:03 PM
You'll be fine-I prefer that method it will sucked everything out and properly filled with the correct weight gear oil then to drain it and end up some debris will stay back-
Feb 26, 2009 at 3:13 PM
