2004 Jeep TJ
2004 JEEP WRANGLER TJ
23,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEVEH1
I'm finishing the install of a 3" TeraFlex lift kit and the swaybar links aren't lining up. Am I supposed to install the longer links that came with the kit. If so, how do you remove the old links? Thank you in advance.[img:20b62fc5ce]http://www.2carpros.com/forum/automotive_pictures/515705_photo_4_2.jpg[/img:20b62fc5ce]
Apr 11, 2010 at 4:56 PM
2CARPRO JACK
  • 11,533 POSTS
Cant quite see what you are working with in thepic, but any tme you move the securing point of the sway bar farther away from the bar itself, you will need to lengthen the end links accordingly.The end links should just unbolt on both ends, they are a serviceable unit so they should come off.If not take a closer pic of the end you cant get off so I can see it better.
Apr 11, 2010 at 6:09 PM
