1998 Jeep TJ jeep turns over, has no spark, fuel pump not w
1998 JEEP WRANGLER TJ
104,000 MILES • 4 CYL • 4WD • MANUAL
RANDJEN1
an accessory light was left on and the battery went dead. Car ran fine before this but now there is no spark, no fuel, but turns over fine. I have replaced the cap, rotor, plugs, fuel pump and crankshaft position sensor. Also I have swapped the ASD relay with a known working relay. Still no luck. Has anyone had this happen? What should I check next?
Feb 14, 2010 at 4:42 PM
Hi randjen1, Welcome to 2carpros and TY for the donation I want you to check fuse no.20 in the power distribution center if okay -remove the fuse and get a jumper wire from the battery positive post to the coil dark green and orange wire this will power both the injectors and coil and let me know what happened.
https://www.2carpros.com/forum/automotive_pictures/12900_asd_relay_8.jpg
Feb 14, 2010 at 5:17 PM
RANDJEN1
I ran the hot wire to the orange and green off the coil but nothing happened. What next?
Feb 16, 2010 at 8:37 AM
I don't have a reference on this Jeep TJ non listed -what I was using is for Cherokee SE-okay do you have power to the coil when you turn the key On and also do you hear the fuel pump come On?
Feb 16, 2010 at 1:05 PM
RANDJEN1
no power to coil and fuel pump not coming on
Feb 16, 2010 at 7:48 PM
I ran the hot wire to the orange and green off the coil but nothing happened. What next? -When you did this and crank engine over do you have spark coming out of the plug wires if not I recommend you have the computer checked out
Feb 16, 2010 at 11:36 PM
