2002 Other Jeep Models High Idle
2002 JEEP
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
KTEACH25
I have a jeep grand cherokee laredo and it has a high idle problem. When I start the car it idles at over 2000 rpm in any weather type. When I shift it into gear it proceeds to go down. When i am driving down the road at any speed but more so the higher speeds betwee 60-70 it tends to rev up. The check engine light will then come on. After a few days it will stop doing this and the check engine light goes off itself. Then it will happen again a few days later, I notice it doing this on longer trips rather than just in town driving. I noticed that since it has been doing this the vehicle will not want to shift twice while I am driving. I will drive at 65 mph with the RPM's up to 3000 and have to slow down to 55 before it will shift finally and I can drive at full speed. please help!
Apr 8, 2009 at 1:15 PM
KHLOW2008
  • 41,814 POSTS
Hi kteach25,
The problem seems to be a vacumn leakage or a fault with the Idle Air Control motor.
As the Check Engine Light was showing, I would suggest a scan to retrieve the code for verification.
Being intermittent, it could be a loose or contaminated wire connection.
Apr 8, 2009 at 1:57 PM
