2001 Other Jeep Models water leak
2001 JEEP
104,000 MILES • V8 • AWD • AUTOMATIC
SUKE
I noticed water dripping from under the right front side tire after shutting off the engine and sitting in the garage. I tried to follow the trip down from somewhere above, but too tight to pinpoint. Coolant is fine, temp gauge showed normal.
Someone said it may be the heater hose? Is the vehicle safe to drive other than the heater is not functioning?
Jan 30, 2010 at 5:21 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Have the cooling system pressure tested as this will locate any external coolant leaks, keep an eye on the coolant level, and get this test done ASAP.
mark (mhpautos)
Jan 30, 2010 at 6:44 PM
