The issue is the misfiring of the engine. The error codes produced(P0303 and P0305) by the Jeep directly indicate multiple cylinder misfire on cylinders 3 & 5. Here is the following OBD-II trouble code diagnosis directly from the site itself:
http://www.obd-codes.com/p0305
http://www.obd-codes.com/p0303
A code P0303 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
I have already had all the spark plugs and wires checked. The engine coil has also been replaced. We can also remove running out of fuel.
this is a on going problem I have also had a valve cleaning done by the Jeep dealer but the engine still runs rough at idle. if i keep the RPMs up it smooths out. can you help?
Faulty coil (pack)
Running out of fuel
Poor compression
Defective computer
Oct 14, 2009 at 6:10 AM
