2000 Other Jeep Models engine won't start and gas gauge read
2000 JEEP
108,000 MILES • V8 • 4WD • AUTOMATIC
VOLLBOB
MEMBER
1 POST
FOLLOW
engine won't start and gas gauge reads zero with 20 gallons in tank
Aug 14, 2008 at 12:19 AM
SERVICE WRITER
CERTIFIED EXPERT
I assume this is cranking?
IF so spray some carb cleaner or starting fluid into the throttle body and crank it. IF it runs for a minute, we know it is fuel related. IF so, check the fuel pressure and determine if it is out of spec. Check fuses associated with the fuel system as well. Post your results.
