1999 Other Jeep Models radiator fan not working
1999 JEEP
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
VGONZALEZ
I have a 1999 jeep grand cherokee that overheated.I noticed that the radiator fan wasn't working. I bought a new sensor & it still doesn't work. I bought the relay for it but I just see a small fuse in the fuse & relay box labeled radiator fan. The fan motor works if I connect it straight to the battery ( So the motor works) I need some help.
Jan 20, 2008 at 7:33 PM
BMRFIXIT
  • 19,053 POSTS
[quote:2dc721c401="vgonzalez"]Engine problem
1999 Other Jeep Models 6 cyl Two Wheel Drive Automatic 115000 miles
I have a 1999 jeep grand cherokee that overheated.I noticed that the radiator fan wasn't working. I bought a new sensor & it still doesn't work. I bought the relay for it but I just see a small fuse in the fuse & relay box labeled radiator fan. The fan motor works if I connect it straight to the battery ( So the motor works) I need some help.[/quote:2dc721c401]
Relay located at the right side of the truck under the right head light box (don’t remove the head light wont help)
remove the battery and move the power box and work you way under the head light liner black square 4or 5 wires two bolts
good luck
Jan 20, 2008 at 10:20 PM
