1999 Other Jeep Models CRANK SHAFT SENSOR LACATION
1999 JEEP
120,000 MILES • V8 • 4WD • AUTOMATIC
CJROTH27
Where is the crank shaft sensor located on my 1999 Jeep grand cherokee? thanks
Feb 19, 2010 at 9:18 AM
On right side of engine block,above starter motor.
https://www.2carpros.com/forum/automotive_pictures/12900_cp_1.jpg
Feb 19, 2010 at 5:11 PM
RIPNDR27
  • 4 POSTS
I just did this a few moment ago. It is located behind the starter.Look just behind the transmission on the passenger side. It is hidden quite well as I found out, but once you remove the starter, you will see it very clearly. What problems are you having with you vehicle?
Apr 14, 2010 at 6:03 PM
