1999 Other Jeep Models Cause of P020 misfire codes
1999 JEEP
100,500 MILES • V8 • AWD • AUTOMATIC
MIKE PRESTLY
Our '99 Grand Cherokee LTD with the 4.7 L V-8 has had an issue with only occasional eratic idle, and a fuel cleansing from the local Jeep dealer helped alot for awhile. While towing an enclosed trailer long distance, the check engine light appeared and stayed on for the next week. The speedometer seems to have occasional rapid fluctuations of approximately 2-4 mph. The Jeep also has the tach 'bouncing' while traveling at a constant speed down the road. It acts almost as if the lock-up torque converter is unlocking and then relocking repeatedly. While the diagnostic computer was attached to the vehicle it detected the misfire codes P0201 and multiiple other cylinders are involved. Also cylinder #1 was only firing maybe one out of every 6-8 cycles. The local independent shop that read the codes mentioned that the only other vehicle they have seem with this same problem of misfires was a Durango with the same 4.7 L and it needed an entirely new ECM to solve the problem. They are not sure that ours will need the same. With the expense of a new ECM, we are hoping to get a more specific answer. Do you have any ideas or information?
Jan 10, 2008 at 7:20 PM
FISHERMAN
  • 937 POSTS
[quote:4fcde10359="Mike Prestly"]Engine problem
1999 Other Jeep Models V8 All Wheel Drive Automatic 100500 miles
Our '99 Grand Cherokee LTD with the 4.7 L V-8 has had an issue with only occasional eratic idle, and a fuel cleansing from the local Jeep dealer helped alot for awhile. While towing an enclosed trailer long distance, the check engine light appeared and stayed on for the next week. The speedometer seems to have occasional rapid fluctuations of approximately 2-4 mph. The Jeep also has the tach 'bouncing' while traveling at a constant speed down the road. It acts almost as if the lock-up torque converter is unlocking and then relocking repeatedly. While the diagnostic computer was attached to the vehicle it detected the misfire codes P0201 and multiiple other cylinders are involved. Also cylinder #1 was only firing maybe one out of every 6-8 cycles. The local independent shop that read the codes mentioned that the only other vehicle they have seem with this same problem of misfires was a Durango with the same 4.7 L and it needed an entirely new ECM to solve the problem. They are not sure that ours will need the same. With the expense of a new ECM, we are hoping to get a more specific answer. Do you have any ideas or information?[/quote:4fcde10359]
Hello Mike!!
My advice its to switch the injectors from #1 to #6 and see if the #6 its misfiring...
also check the resistance on all of them...
the problem can be as easy as a faulty injector/s!!
(could be that couple of them are faulty)
P0201 Injector Circuit Malfunction - Cylinder 1, does not respond properly to control signal
Specific P0201 its just cyl. number one!
let us know on your findings!
Jan 10, 2008 at 7:45 PM
MIKE PRESTLY
We had the fuel rails and injectors cleansed and blown out physically and with a high pressure cleaning system. All misfires have so far been solved, only time will tell if it continues to work.
Jan 17, 2008 at 8:33 PM
FISHERMAN
  • 937 POSTS
[quote:78a6e517ea="Mike Prestly"]We had the fuel rails and injectors cleansed and blown out physically and with a high pressure cleaning system. All misfires have so far been solved, only time will tell if it continues to work.[/quote:78a6e517ea]
Only Time... (Enya)
Sound good Mike!
Good Luck!
Jan 17, 2008 at 8:55 PM
